Hello SketchUp community. I need to hire a SketchUp developer to create a custom plugin that would function as follows:
User selects one or more SketchUp surfaces (coplanar is fine). This might involve filtering the selection for surfaces only (and possibly not the edges).
Loft all the selected surfaces by 3/4” (if user input is needed to indicate the direction of the loft, that is fine).
Add a 45-degree, 3/4" chamfer to all the edges of the surface created in step 2 above.
Assign to the new surfaces and chamfered edge surfaces / geometry the same material definition as the parent surface (on a per surface basis – each selected surface might have its own material definition.
Turn the new geometry into a group (the name is not important).
Put the new group on a user defined layer (or tag) to control when the added geometry is visible.
These operations should leave the parent surfaces unchanged.
Thanks in advance for your consideration!
Jeff Leonhardt
