Load Errors upon Startup
If you are getting load errors on startup, the errors should tell you which extensions are having problems. You shouldn’t have to disable the whole lot.
Which version of SketchUp are you running? Your profile is incomplete. When you installed SketchUp, did you then install fresh copies of all the extensions or did you copy them from an older installation?
