LO 26.2.242 don't allow override default line style of SU model
LO 26.2.242 don’t allow override default line style of SU model.
It seems to accept overridings (type line, color, scale, thickness) but, nothing happens…
check your style in sketchup. check the line parameter, you need to enable dashes (the one parameter without line thickness)
if you turn it off, it overrides tag’s lines parameters.
The same file, open in LO2025, works perfectly.
In LO2026.2, overriding behaves in a strange way, if tags are in folder.
It works ok, if tags are not in folder.
Oh yeah, that’ a known bug. lots of things went slightly wrong with layout 26.2
I’ve been reporting what appears to be a serious bug similar (maybe the same) to this.
In respect of styles – files that worked in previous versions do not in 2026.2.
Any progress on this, time frame, etc.?
nope.
there won’t be any fix until the next update. and as summer is now upon us, chances that we see a 26.3 with fixes for layout before a 27 (with fixes?) are becoming suuuuper low.
Looks like two things are certain for this summer, heatwaves and broken layout.
Maybe we won’t see any fixes for some issues Pierre :wink:
Just saw this yesterday… exploded the folders in SKP and was able to carry on, but it is a PITA that things keep breaking behind the scenes.
they are probably too busy fixing the odd translation first, that’s all :innocent: :melting_face:
I cant change line weights either, what can I do? this is sort of a serious problem as I am trying to get a set of construction documents out of the door
I think your options are:
Explode your folders in SKP.
Work in 2025 until it’s fixed.
there is no other fix? this was working on '26 before one of the last micro patches and now our working documents are completely overhauled by a bug that wont be addressed?
this is a major issue in our office at the moment. One of our employees updated and now we cant regress back a couple micro patches ago..
We are on mac, is this windows?
Ah … Another one of those Mac only bugs.
No other fix.
I keep old versions around just for these occasions.
I do with that SKP kept all minor releases available on the download page.
do you use a mac and do you have version just before 26.2.242 by chance? :pleading_face:
No… sorry I don’t.
This posted in other topic:
