Hello!
Is there any way to convert lines into arcs?
Hello!
There are at least a couple of extensions that can convert lines to arcs if an arc can be made. Eneroth Auto Weld and Exploded Arc Lines to Arc. There’s probably more. Thy require the segments are all the same length and the angles between consecutive edges are the same. Welding the edges with the native Weld will create a curve.
If you want to practice without a plugin, click in sequence on the Scenes tabs of this SU file for ideas:
Edges to arc.skp (288.4 KB)
Thanks!
Thank you!
