I want to draw over some of my Sketchup viewport images in Layout, but the pencil tool will only start at certain points that don’t line up with points in the viewport model. When I move the line tool around it jumps from point to point.
Most likely you have grid snapping enabled. Go to the Arrange menu and turn it off.
Thanks Dave! That did the trick. I just didn’t know where to turn off the grid snap.
Glad that helped. If grid snap isn’t something you would normally want, you can create your own template that, among other things, has grid snapping disabled. Then you won’t need to worry about it.
