How can i do it? Please help me
Hello, i’m completely new to sketchup because i just started in the 3D printing world. I just downloaded the Libfredo6 and Joint push pull plugin for a design but i can’t find a way to make it work for my needs. I need to extend de distance between these two points from 20mm to 24mm wide.
You don’t need JPP for that, just select the geometry and move it 4mm.
If you attach your model someone might be able to show you how.
Sure, here it goesFX6SU8JJUQS8NCW.stl (74.5 KB)
I already tried with the stock push/pull button but it doesn’t seem to work (or maybe i’m not using it well)
In future add the .skp file not the .stl unless asked for it.
Select left to right so it only selects what is inside the fence, then start to move it with the move tool and type 2mm then hit enter.
Repeat for the other side.
And if you only want the ‘groove’ to change, just select those parts.
