I’m trying to export a layout drawing to autocad DWG format but keep producing bad results that the engineers can’t use. I am unsure whether the fault lies in the Layout file organization itself, or maybe I’m exporting it improperly.
Note that the "Export for SketchUp option produces a DWG image of your LayOut page in DWG Model Space. The result is in paper space scale. To get plans to full scale the result must be scaled in a CAD application.
You should go through the options to find which one suits your workflow best. I would export only pages where viewports have been set to use Vector rendering, to avoid embedded raster images. Engineers have no use for them.
Thanks. I’ll give it a try – will turn off “export for sketchup” and “raster rendered sketchup models as hybrid-rendered” and see if that creates a cure.
Here’s the next try – Layout page screenshot, resulting DWG file, and the export window.
The fonts are clearly a problem. For some reason the structural grid numbers get blacked out (maybe because they’re red in layout?). Other items seem to be translating properly.
Have any more insights as to what I should adjust to get a better result?
