Layout - Scale Drawings
I have set my Layout units to mm BUT when I try to draw in ‘Scaled Drawings’ the units in the ‘Measurement’ box are in inches. The is Layout 2025 on a windows machine.
Did you select the correct units in Make Scale Drawing?
Hi bmike,
Yep. I even deleted all imperial scales and relaunched.
It was in the ‘Scaled Drawing’ This file was updated from 2024. I was amending an existing scaled drawing. It had changed from ‘decimal mm’ to ‘architectural inches’
MANY THANKS>
Yes, that is why I asked if the units were setup properly.
