Layout Not Rendering Textures
I’ve had a similar question before but am continuing to have issues. I have a model in Sketchup (attached) and sent it to Layout. My display and output are set to High, the Viewpoint is set to Hybrid, and both Sketchup and Layout are set to Shaded with Textures.
However, when I export to PDF from Layout, it’s deleting all my textures. I’m not sure what I’m doing wrong.
help1
Sketchup File
Layout File
This is what I get with high res output.
I did not check the box for JPEG compression. Maybe try that. Or try exporting at Medium resolution. Any difference?
Medium resolution seems to have done the trick. That’s very strange - I’ve never had this issue with any of my other Layout files.
Thanks so much!
Make sure your graphics drivers are up to date. I’m guessing, though, that you really don’t need to use High Res for exports.
And you’re quite welcome.
