Can't export from layout
Whenever I try to export from layout to JPG or PDF the program stops respondiing. File sizes that I used to be able to export easily, now get stuck > 8MB.
Anything to do about this?
What version of SketchUp and LayOut? Still using SketchUp 2015 as your profile shows?
If you are exporting from LayOut 2023, check that the Output Override (Document Setup>Rendering) is not enabled. Exporting to Hybrid or Vector rendering is slow, and may fail if your model has a lot of edges and faces.
Great. It worked.
Thank you very much.
Gilead
Ive had the same issue.
This and the bug of not having the paint be able to paint correctly on angles has been a real issue of 2023 SKP for me. Ive had to use older versions for both.
This topic was automatically closed after 186 days. New replies are no longer allowed.
