Hi!
I think Autotext should have able to select multi autotexts for bulk deletetion (or export/import)
For example like this:
Thanks.
Until they make the option to delete multiple Auto Text entries at once, you could edit the file called document.xml in your LO template file and delete the entries you don’t want.
Or, depending on what else you have in the template, it might be easier to copy what you want to keep into a new template.
Thank you very much!!!
