How to set up dimensions in layout so that when drawing a dimension the units measure are NOT displays (automatically). When you draw a dimension it show for example: 2000mm
I want to delete the “mm”. As it take up to much room. Yes I can delete it manually, but how to set it up so that the “mm” (millimetres) is not display at all.
Yeah, those buttons are a little hard to figure out at first because there’s no text on them. If you hover over each button with your mouse cursor, there should be a tooltip to give a bit more information.
