Layout creates duplicate viewports, text, lines, etc. Sometimes the same viewport on top of four others. LO file is attached.
This poses all sorts of potentials for errors
No LO file attached but I’m going to guess you are putting the content on a shared layer which means it’ll show up on every page if that layer is visible for the page.
Also guessing the LO file is too large to upload here directly. Upload it to Drop Box and share the link.
Yep, file wouldn’t upload. Dropbox link below.
The 1-plan and 1- elevation layers are shared so as I wrote, anything on those layers will show up on every page if those layers are visible. Note the icon on the far right in the Layers panel. Generally shared layers are used for things like title blocks, paged borders, and page numbers that will be the same from page to page.
You also seem to have weird things like this map is on the 0-Poche layer on this page.
The only bug I see is in the way you are using shared layers.
I’ve found that when holding the CTRL key to select multiple entities (text, dimensions, viewports, etc.), inadvertently clicking on the same entity again will place a copy in the same place.
