tldr; gridlines show up properly in LayOut 2025 but not in LayOut 2026.
With the general rule of only groups and components placed on user generated tags and geometry on ‘untaggged’ my grid lines (which have multiple nested parts, 2d linework [for plans] and 3d planes [for elevations], all of which are on different tags for control). At the highest level the groups (not nested geometry) are set to the tag with a linetype. LayOut 2026 appears to not respect the ‘default’ setting for the tag linetype they are set to and the linework needs to be put on the tag with the dash to display properly in LayOut 2026. In other words, my 2d gridline geometry(the lines) are on ‘untagged’, but multiple levels up, and other tags with linetypes set to default, they are set to a tag that has a dashed line type. LayOut 2026 shows them a solid line and will only be dashed line until I place the lines on the tag with the dash line type. Layout 2025 shows them as the dash they intended to be.
Upon further testing, and making of attached files, in raster mode, they show up properly, in hybrid or vector they do not.
Linetype problem.skp (559.9 KB)
Linetype problem.layout (532.0 KB)
