Layout 2024 Autosave location?
I had a computer crash (system, not layout specifically) that forced a hard shut-down as my system froze. Is there a chance that my 5+ hours of work in Layout is saved somewhere? I had neglected to save the file along the way as I was on a roll.
My guess is there’s a slim chance but you could look in the following. Note that AppData is a Hidden folder under your user name. You can make Hidden Folders visible in File Explorer. There might be a file there.
Screenshot - 8_2_2024 , 12_52_52 PM
When you opened LayOut did the Welcome window show any recovered files to open?
Recovered files do show up when I open Layout, but this specific file does not appear. In the system folder that you referenced, there is a folder with timestamps that match today’s work. Do you know how I can get this info into a new file?
Open the folder and select the contents. Use an application like 7Zip to create a zip file of those files and folders. Change the extension from .zip to .layout. Move the file to your desktop or somewhere. You should be able to open it with LayOut, then. When you do that, immediately save it with your project name and update the SketchUp reference if needed.
File successfully recovered! Thanks, so much, Dave! I’ve already saved it this time.
I did need to download 7Zip, as the Windows “compress to zip file” did not successfully create a usable file.
Good deal.
I find 7 Zip to be very powerful for dealing with ZIP files. Note that if you have an issue with a LayOut file, you can extract copies of the references using 7 Zip without changing the extension.
I am having same issue. I have located the files and followed all these steps but 7zip will not let me select folders and files, just the loose files.
Do I just zip the files inside ref folder?
What exactly are you trying to do?
No.
If you have the exact same situation as the OP had, you should be able to select all of the associated folders and files, use 7Zip to collect them into a Zip file and rename it to .layout.
The Ref files should not be zipped within the ref folder.
I don’t understand 7zip, beyond my basic knowledge of computers. Do I select folders and press Add and save as zip. Then go to saved location and change to .layout?
You can open the 7zip UI, add folders and files and so on. I just open File Explorer, select the files, right click on one, choose 7zip and Add to xxxx.zip.
7zip
This topic was automatically closed after 186 days. New replies are no longer allowed.
