LAYOUT 2022 - TEXT - How do I set a font and size as a default when working in LAYOUT 2022 ?
command-t
It opens the standard tray for text on macs.
From memory, it’s also either in text or window menu.
edit : yeah, bottom of window menu. command T.
Moved to the LayOut category.
The default is determined in the settings for the opened template or document.
In order to have one is to set up your own template.
To do this ( and not have it switched back ) you must activate the text tool, adjust the settings and place it. Then delete the text and save as template via the file menu.
