We are renovating a house in the Netherlands. In the living room there is a fire place we want to rebuild. I have all the existing measurements and want to set it up in SketchUp, so that I can play with different measures, colors, etc.
Can anyone (in the Netherlands, maybe?) help me setting it up. I do not mind paying for it…
I’m sure people will come to ‘help’ but realistically this is a user forum about using the software. It’s not somewhere you normally ask for a model, and rarely not one from which you would take measurements. Sounds like a skilled person might be required that can assist you with fireplace safety standards.
And, especially if it is an open fireplace, to ensure that the smoke goes where it is intended to and that it has correct dimensions in relation to the chimney.
You may want to contect me to see if I can set you up. Either by meassage or through posting here.
I live in your flat country and don’t accept any payment.
We can at least try.
Wauw, super. I managed to create the living room with doors and windows…Now a fireplace like structure on one of the walls. I have to run, what would be a good time for you? By the way, I live in Huizen…
This is only visible in the SketchUp Viewer.
It would be more convenient to work with the file itself.
I send you a message through the forum. Right click on my avatar and then on “Message” (top right) to then include the file of your model. To discuss the setup.
