I have sketchup go for ipad. I want to export my model to google earth. It seems that there is no option for .kmz file in ipad version. How to do it?
I see the .kmz option in the SketchUp Go for Web version. Can you open your model in that?
Hello @p9wk2rtkbq,
Anssi’s suggestion is probably your best option right now. iPad does not currently support .kmz file export, but if you have a Go subscription for ipad, you get access to SketchUp Web as well. I suggest saving your file to Trimble Connect on your ipad, then logging in with the same account on Web and opening your project there (it will be available through Trimble Connect). Once you’ve got it open on Web you should be able to export your .kmz
