JOINT PUSH PULL issue
Hallo,
could you help me? I try to use plugin joint push pull for the chair but it doesn´t work properly. Or maybe I don´t know how to use it :slight_smile: When I apply joint push pull plugin I still miss the inside face of the object.If I use plugin from the inside I miss outside face of th object then. What I am doing wrong?
Thank you .
Bea
sorry, solved :slight_smile:
