Joining offset corners all at once
Hey sketchup community. So I have this neon tube I would like to create along this path and I imported it from sketchup. The first thing i did was offset the lines to the center so I can build the path for the follow me tool but I would like to know if there is a better or faster way where I can join all the offset lines together so that I have a follow me path that is centered in this tubular structure. What would be a good extension for this use? The first pictures shows the corner missing a line because it is offset while the second picture shows the path I want the tube to go. Is there a quick and easy way of doing this and also would I be able to bend the tubes so that they go higher or lower?
I think the best way is to use the follow me tool after you join the lines
Create a single path (not 3) along the desired route, including the ups and downs.
