JHS Powerbar not loading on Sketchup 2018
I have the 2018 version of Sketchup and apparently the JHS powerbar plugin doesn’t seem to load up in it whereas the other JHS plugins do. Is there a fix for this?
You must have installed an old version of JHS Powerbar. Did you just copy it from an older version of SketchUp? It has been updated to work even with SketchUp 2019. It’s available here. Or better, install it using the Sketchucation Extension Store Tool.
Thank you, it worked!
You’re welcome.
I’m curious. Did you just copy it from an older installation or did you get it from somewhere other than Sketchucation?
How about marking my post, above, as the solution so others will know if they have the same problem?
