Is there anything similar to action in photoshop in sketchup?
Is there anything similar to actions in photoshop in sketchup? So that we can make intresting commands like Top and parallel projection together in a short key or create a group of functions like setting up a style for exporting to layout ext
SketchUp does not support macros or strings of commands associated with a single shortcut. The properties you listed would be controlled and saved collectively using scenes in SketchUp. Camera position and type of perspective, style, visibility of layers/tags and individual objects, shadows, fog and more can all be recorded and then instantly recalled to using scenes.
Assign a shortcut to top and a shortcut to parallel then you could use AutoHotKey (Windows only) to assign a hotkey to perform top then parallel (or the other away round).
I use AHK a lot with SketchUp.
