Is there a way to reset axes?
Oops, I inadvertently set my axis wrong so the blue points where the green should be etc.
Is there a way to set it back to default?
right click on an axis and click “reset”…
john
Thanks! It worked…though I had to hunt around for the right axis for a while.
You can click upon any of the 3 axis that combine to form the model axes. You do not need to click upon a specific axis. Any one of the 3 will add the “Reset” command to the context menu.
what to do if the reset option is frozen? i am having problems making rectangles directly on the surface, it only works on strange angles- seems to be an issue with the axis
any ideas?
Can you share the file? That may indicate that the axes are in the original position.
Wonderfull. Thank you.
Accustomed to using the UCS on AutoCAD and it is very useful.
tx, Ed
Long time ago it was, 4 years, but your problem was exactly mine today in '21. Lost time and work. That simple Reset solution has made my day. Imagined nightmares about future potential Axes problems are now put to sleep. New Thinkings.x2
