I am doing a model of a site from the imported terrain countours I have in Autocad. Is there a way to fill the faces automatically? There are very small gaps which I have to keep filling over and over, which makes it very time consuming. I wonder if there is any way to fill it more easily. Thanks
How about using the Sandbox from Contours tool?
I can create the faces, but it’s created as a smoothed/curved surface and I can’t push/pull it.
If you just want to create faces automatically, then you could try the plugin - Extension | SketchUp Extension Warehouse
But as your example looks, it should be better if you arrange those very close edges that intersect each other.
You can push pull a curved surface, if you need
Eneroth seems to be the best option, altough there is one or two gaps it didn’t fill. Thanks
Thom thom’s edge tools can close gaps.
Check out The Learning Center Landscaping course. Has a list of tools to use plus a great tutorial.
