Hi!
Is there a tutorial to design/create laser cut pentagon shaped box with finger joints? I will be cutting on a Glowforge laser printer. I am new to Sketch Up.
Thx!
Cindi
Hi Cynthia, Welcome to the forum!
I doubt that there is such a specific tutorial.
If you are new to SketchUp, the best place to start learning is learn.sketchup.com
Also SketchUp has a YouTube channel, search for the Square One series.
https://youtube.com/playlist?list=PL-bndkJaV8A7R2t970OmHY6kPGJwTfGP2
That’s about the SketchUp basics.
After that you could try the Skill Builder series that go more in depth…
https://youtube.com/playlist?list=PL-bndkJaV8A5VmrwvxMw-IYgSJLlV-vjH
After that, if you have some questions about specific problems you can always ask here and someone will sort you out!
Thanks so much for your speedy response! I’ll go check out the tutorials and browse around the forum. Cindi
Thx- I did try maker case, but all of the tabs don’t stay connected when I try to move them.
I would also like to use the sides to create a template to design houses. Do you know how to keep all of the sides from moving around?
I opened it in Illustrator
