Is is possible to create construction points in the C API?
If not, what is the most efficient way to create them in the Ruby API?
Creating them one at a time with entities.add_cpoint is very slow.
EntitiesBuilder does not appear to support construction points.
AFAIK, the “Live” C API is still read-only.
However, you could make sure the model is saved, then close it (ie, by starting a new empty model.)
Open the model file with the C API and add your guide points.
Then save it with C API, release it and then reopen with the Ruby API.
Did you wrap the batch creation in a undo operation with the disable UI switch true ?
model.start_operation("Add Guidepoints", true)
  ents = model.active_entities
  points.each { |point| ents.add_cpoint(point) }
model.commit_operation
In the above example, the points array would be calculated outside and before the creation loop.
I’m seeing a couple of microseconds per cpoint added. What kind of speed are your looking for?
model = Sketchup.active_model
count = 1_000_000
t = Time.now
model.start_operation('add cpoints', true)
  count.times { | i |
    ents.add_cpoint([i,i,i])
dt = Time.now - t
puts "#{count} cpoints added"
puts "\u0394t = #{ dt } seconds"
puts "#{ 1_000_000 * dt/count }us per cpoint"
nil
I had not set the disable_ui flag to true. Thanks for that tip.
What is this file you have posted and how does it pertain to the topic ?
Sorry for this mistake, about 9 months ago my PC was hacked, my personal accounts were cloned, so possibly those who were trying to harm me made these posts.
Until now, I was not aware of this post.
I have already deleted it, please check if the file is still on the forum.
Thank you in advance for notifying me of what happened, this way I was able to delete it so that it wouldn’t cause any more trouble on the forum.
