Point3D does not work
Hi All,
I am trying to plot 3D points using Sketchup. I used the Point3D code and the suggestions that are given on the following webpage, but nothing happens. Does anyone know what I am doing wrong?
http://www.sketchup.com/intl/en/developer/docs/ourdoc/point3d
Thanks,
David
Make sure that you have set guides to be visible in your model. (View > Guides)
If that isn’t the issue, then please post back exact code snippet you are trying and any errors you might be getting.
Yes the Guides are visible. There are no errors when I use the code given.
David
Ah, I should have understood what was going on when you first posted, alas.
Geom::Point3d doesn’t represent an entity. It’s a general data structure.
What you want is Sketchup::ConstructionPoint which you add to the model using Sketchup::Entities.add_cpoint.
point = Geom::Point3d.new(1, 2, 3)
Sketchup.active_model.active_entities.add_cpoint(point)
The Sketchup::Entities class’s add_* methods are what you use to add any kind of entity to the model.
Thanks for your help. I used the information you gave me and looked up
this link.
http://www.sketchup.com/intl/en/developer/docs/ourdoc/constructionpoint
The above link provides everything I was looking for.
David
