Hello there,
I have a problem with my installation.
When installing there comes an eror box.
I have seen a similar problem in the topics but I couldnt make it to fix it.
Can you please help me?
Thanks
Hello there,
Thanks
Did you rightclick on the installer file and chose: āRun as Administratorā ?
That should take care for permission, normally.
Yes I already did this lot of times but with no result! ![]()
Depending on your Windows settings, you may need to log out and back in again with a local administrator account. The āRun as Administratorā option will not necessarily give you full access to everything.
Thank you for your help.
I also followed your proposal but no change⦠![]()
The same error
Have you checked the permissions on the registry key? Mine show this:
Here are the entries:
I finally found a solution by installing this program which fixes the most problems with registrations.
Thank you all for your responces ![]()
The program bellow:
Tweaking.com - Tweaking.com - Windows Repair Free/Pro
lWindows Repair
