I imported a simple lot layout from dwg to sketchup, but i have some lines that won’t create a surface… even if i want to just redraw it, i try to draw over, it doesn’t work, nothing happens. if i draw a big rectangle over it, a ‘hole’ forms. I tried flattening, making sure everything is a polyline on cad, saving in a previous version, flattening extensions, welding extensions, face forming extensions, changing edges colors. to me everything seems on the same plane.
in the attached file, you will find 3 different layouts to create 3 options for my project. you will also see that for each one of the layouts, the faces form differently, but still don’t follow the building lines i want Untitled3.skp (137.6 KB)
thank you!
thank you, i did find one more, but didn’t solve the whole thing
although i see that you have a face that formed under the parking area, how did you manage?
sharing if it helps someone :
the parking lines were making the program confused apparently, so i removed them from the autocad file, then used the Edge tool extension to find the remaining gaps and close them. I used it before but it didn’t work and i just clicked that it was identifying all the parking lines as gaps so thought maybe sketchup was doing the same.
