Hello,
I know that you’re not supposed to be able to import .dwg files into SU Make - is there an extension that allows you to do this?
I imagine not, but just in case…
Kaiden ![]()
Nope. You need SketchUp Pro or Shop to import .dwg files.
Awh. Oh well ![]()
It’s a proprietary file type and requires a licensed importer.
Thank you!
There are still plugins around to import the DXF format that is the Ascii version of DWG. Here is the first one I found:
https://sketchucation.com/forums/viewtopic.php?f=323&t=22199
You can use the free DWG TrueView application from Autodesk to convert a DWG file into DXF.
Cool, thanks! I’ll have a look later.
Kaiden
