Imported autocad file into sketchup shows all white when setting color by material. Please assist
How many layers does the .dwg file contain? Did the geometry have assign layers? Do you have more tags in the model after importing the dwg?
It only contains five layers.
Yes, all have been assigned to its corresponding layer.
No, only exactly five layers from AutoCAD appear in the tag.
Have you applied materials to geometry or objects?
Isn’t maybe there a setting that can assist with this. this is quite a big drawing to apply color to each object.
If they have correctly assigned tags, you can easily select and apply material in probably 2-3 clicks.
or see this:
Man, you’re a life saver. THANK YOU VERY MUCH. This video worked
Materials applied in AutoCad are not imported into other applications - they are only visible in the AutoCad internal renderer.
