I made an ifc from a building. An engineer says my levels for 1. and 2. floor is all wrong. The ifc coded leves are both set at +0,2m, he says. I guess I dont really know how to structure the hierarchy of site-building- storey correctly, but does that affect the levels?
In the model my two storys obviously are not on the same height. They display geometrically the correct height.
What is it really that defines the storey level? I want the value for 1 floor to be 0, and the next to be +3,95m
The engineer say that when he places objects, dont know what software it is, but objects that are supposed to be places at an certain height above the floor, like a sink, he needs to put in absurd number in order for the geometry to be shown correctly.
Yes, @rtches is right about the structure. I might add that it seems to me that if in any one ifcStorey component you have anything whose bounding-box goes below the physical storey-height level, then things get messed up when the resultant ifc export gets opened in other software (mis-interpreted), am I right ?
I got it sorted. Its not clear that the engineer´s software DDS-cad, (never heard of it before) reads ifc correctly, but the solution in this case was to correct the axis system for each building storey, and package those two storeys as ifcbulding before export.
Taking the slab for 2. floor out of the 2 storey component in order to not have geometry below the level for the storey didn’t produce any effect, it seems, in this case.
