HTMLDialog #show vs #show_modal and #close
I can create an HTMLDialog box and use UI.start_timer and #close to close it after a period of time.
The HTMLDialog box has a title bar.
Does show_modal create a dialog that has no title bar?
If I use #show_modal, using UI.start_timer and #close won’t close the dialog box.
Yes.
Yes.
No.
Yes. Because modal means waiting for user interaction and Ruby will wait to execute the code lines after show_modal line (here UI.start_timer) . Therefor a block inside will not happen. User must close the modal window manually or the dialog itself have to send a callback to Ruby.
Then the code execution continues.
Actually you can close the modal HTMLDialog like:
this will close it after approx 5 sec :wink:
dialog = UI::HtmlDialog.new
UI.start_timer(5) { dialog.close }
dialog.show_modal
while with non modal dialog this will work too:
dialog.show
Term for today
