Hi, I am basically trying to make a room.
I have drawn a rectangle and used the offeset tool for the walls.
I have saved this in a group called floor, and added a layer floor and saved it in entity info.
Now i would like to push pull the walls but want them to be seperate from the floor, in the layer walls
I cant turn the floor layer off to do this and if i seperate the two they are in the same group so i cant add a layer
where am i going wrong please?
x
DaveR
2
You should take the time to go through the SketchUp Fundamentals training.
@loulou,
Draw a rectangle. Offset its edges inwards.
Double click the inner rectangular face (to get the face and its edges selected > right click > ‘Make Group’.
Double click the wall face (to select the wall face and its inner and outer edges > right clcik > ‘Make Group’
You now have created two groups: floor and walls
Only now you may want to apply different layers to assign to each respective group, although not a must.
You can edit one or the other or both groups by entering their contexts
the basics…
using copy >> paste in place
john
thank you - thats a massive help i get it x
the default apple keyboard viewer, under the flag in the menu bar…
john
