Hi. How to rotate array a series of object with different angles?
I try get ten boxes in line, but every single box is different rotation angle. First 5 degree, second 10 degree, and so on… But there are in one line. Is that possible with array modifier? Who I can do it. Any ideas.
Thanks.
I would use the smallest increment as the rotation angle and as the number of copies the total angle divided by the increment, and then delete the extra pieces. Otherwise you would probably need an extension that doesn’t exist.
Try CLF Component Stringer extension. Or Skatter, or Profile Builder. Or Curic Space.
You can use Sketch PLUS extension and Random Rotation. It has trial period, so you can try, does it work for you
