Is there a way to remove models from a project in Trimble? I am trying to completely reorganize my work. I want to start all the way over and categorize all of my models but cannot find a way to remove them from each project.
Do you have a Windows Machine?
It is possible to delete them from the trimble connect windows software, there´s also an iOS app where you can manage your projects, I don’t really know why there’s not a mac version, anyways, you must first download the file to your device and it will give you the option of deleting from trimble connect and your device.
Here I leave the link for downloading the version you preffer.
Edit. I probably misunderstood, if you just want to delete objects from files stored on trimble connect, you must download the file and using sketchup, delete the objects and overwrite the file when you save it to trimble connect.
Trimble Connect for browser is not OS- specific, it’s running in a browser:)
The catch is to use the checkbox in order to see the details and actions that are available:
Keep in mind, deleting them in the browser (= Trimble’s cloud server) removes the file from that project. In order to rearrange into a different project, you need to download it first! ( you cannot move files/folders from one project to the other.
Making use of the synctool, this process is much easier.
First make sure everything you need is locally available and organized, then set up the project(s) and set the schedules dor syncing in the sync tool.
Trimble Connect still remains an unexplored topic for me. I’ve looked for tutorials on how to organize files, how to switch a model from one country to another, or even from one continent to another—but nothing has worked so far. I should probably try searching again; maybe I missed something.
@francisquitof No I am on mac unfortunately.
Thank you for your responses. I am not wanting to delete anything from Trimble just simply reorganize. I have all of my model files in different projects but would like to delete the projects but keep the files in Trimble so i can reorganize and recategorize them. Is there a way to take a file out of a project and have it just as a file on tremble or move it to a different folder or project?
You can’t move them, but you can save them to a different project.
Either open a file from inside a project using the trimble connect menu in SketchUp
then choose save to trimble connect and save it to the project you want to have it part of.
Alternative you could just download all of the files from https://web.connect.trimble.com/ and upload them to where you want to keep them
You could also look at the desktop folder sync app for mac OS
Thanks for the advice. Hopefully one day we can actually organize files in Trimble without having to do a bunch of extra nonsense.
