i want to purge unused entities in skp file, such as “Purge Unused” in SketchUp, how to do it? is there any API in SketchUp API?
There are purge API methods for components, tags[layers], materials and styles.
You need to do them in that order - because components can keep materials etc, resulting in the purging being only partial…
You should look at, and get inspiration from, my well established extension, available here…
https://sketchucation.com/pluginstore?pln=PurgeAll
This is posted in the C SDK category.
Do you need to do this outside a SketchUp application process?
I can only find 2 function about purge:
SU_RESULT SUModelPurgeUnusedLayers(SUModelRef model, size_t* count);
SU_RESULT SUModelPurgeEmptyLayerFolders(SUModelRef model, size_t* count);
just in model.h file.
is there anyother function about purge?
where are the purge API methods for components, tags[layers], materials and styles?
If you notice in the subsequent post you referred to the API and I replied to that assuming you meant Ruby.
In that API there are the methods I mentioned.
I don’t know about the C SDK methods…
If the method ...SUModelPurgeUnusedLayers(...
etc exists, then logically there should be some equivalent methods for Components [Definitions], Materials and Styles ??
Except for Layers (aka Tags,) they do not exist in the C API.
You must write your own iterator functions that determine whether the resource is used or not. If not then you can queue it up for removal.
