How to Pierce a Solid with a Hole at a Chosen Angle
I want to pierce a solid with a hole at 75 degrees. This will represent a dowel piercing a board. I can draw the dowel at the requisite angle but cannot figure out how to have its center axis pierce the board at the correct point.
I searched, but I couldn’t phrase an argument that returned a hit.
TIA
Make a cylinder out of the piece, then insert into position you want and use “intersect” tool.
Click in sequence on the scenes tabs of this SU file for ideas.
Inclined dowel through a board…skp (275.9 KB)
Another way using Make 17 native tools;
Thank you, gentlemen!
I needed reminding of the Intersect command. I rarely use it and had forgotten it.
That’s a good idea Guido.
That makes a solid item … Neat But I need a hole THROUGH a part at say 97 degrees Hole like say 3 inches in diameter . . 7 degrees off Horizontal . . Up grade Part for my Veggie slicer For Carrots . . Make Salads faster LOL … using Push Pull I get left over stuff And wen I delete left over hold goes away !
It sounds like you are missing some simple step. If you can share your model here (drag and drop into the reply window if less than 16MB), we can give a more definite answer.
Thanks for the help.
