Is there a way to open an imported or a chosen component skp file from within the current model?
I mean, not double click and editing, but get the original skp file loaded.
I have for example and illustration, a Site.skp file within there a Terrein, Building and Garage components.
I would like to open the component.skp file.
Is there a way to do that?
If posable, by using Ruby, to add a menu item inside the contextual menu from a component?
If not there, then anywhere else for that matter?
Hi dave, thank you for your reply.
I know that, but that was not the question.
I have many, twenty plus, components already made and imported. Some are almost the same but with little different details. I donât want to search for it.
Whatâs the problem, then? Did you give the components useful names so you can select them from Outliner? If you want to edit a component, whatâs wrong with editing it within the current model?
For all intents and purposes editing the component is you editing the SKP file.
However itâs always contained within your main project file.
As DavrR says, you can export it out and open it in another sketchup instance if you wish, but you would still need to reload it inside of your main file to see any changes.
So far as I can see it doesnât work, looking at the code my guess for now is the non writing privileges for the Tmp folder on the Mac. There are some comments I saw in the plugin description comments, will read that in the weekend and compare it with other writing methodes in other pluginâs. MaybeâŚ
You could ask at sketchucation and perhaps Tig will update it for you or help you update it depending on the licensing.
There may also be a newer option.
Huh funny, it did saves a file with a copy of the component somewhere in a system private folder ( there are now 14 skp files in there ), but SU did not open that file, but just once.
SU podium comes with a built in extension âEdit in Placeâ.
Not sure if it is still available out there as a standalone extension.
Maybe in the the German archive @SketchUp3D_de ?
Would like to confirm that this plugin works fine on latest and greatest (Windows Version). Honoluludesktop(RIP) may rest in peace knowing that his creation has stood the test of times.
