How to make in model textures work
I’m trying to use a image of oak to put on my model. So, I use the image with the grain going vertically and it becomes a in model texture. So far, so good, now I want to rotate the texture to the vertical and all the textures change to vertical. I can’t make it produce both a vertical and a horizontal texture for the in model texture.
You need to apply the texture to the faces in the model. Then you can rotate it for just the appropriate faces.
You can see how the wood grain textures were applied with the correct direction here.
OK, that makes things clearer. Thanks
