Hi all,
trying to figure out how to make hexagon to follow curved line. No success with follow me.
Extension maybe?hexagon.skp (85,4 Kt)
SU Make 2017
Hi all,
SU Make 2017
That’s what I got too.
Thanks DaveR and Box,
not quite what I was looking for (my fault, poor diction).
Hexagon should remain constant but following the line ie. curved hexagon tube.
Then you need to turn the hexagon 90 deg so it follows the curve.
And the hexagon is too big for the curve you want to follow.
Thanks again,
jep, still lots to learn.
DaveR’s picture is kind of what I’m looking for.
I’ll make some adjustments and hope for the best.
Maybe like this?
Run Follow Me for one arc’s worth and then copy the result. The first segment of the path would need to be perpendicular to the profile. I used half a circle split at mid points of opposite sides instead of an arc.
You could also draw the appropriate sized larger arc radius in the path. Think about the path the bottom vertex on the hexagon follow in my example.
Thanks DaveR,
got it.
