How to make a ramp
hi, im trying to make a ramp that connects to a sidewalk. it was like curve and i cant find similar tutorial on this. this is how it looks. how to do it?
I’d probably do something like this.
Figure out the shape you want along the curb for the transition from high to low so you have a closed loop of edges between the radius and the apron slope. My curve may not be what you actually want.
Then select those edges and use Skin Contours from the Curviloft extension. This is the extension showing a preview of the surface.
And the result.
The resulting group can be exploded to merge with the other geometry if desired.
hi, i cant do it the way you do it. Am i doing it wrong? this is what happen when i do that
wait, i think i did it. THANK YOU SO MUCH
Good deal. It really just depends on the shape you need. Remember for things like this that you need a closed loop of edges for Skin Contours to work.
