I cant find the command
Put the edge in a group or component and assign the group/component a tag. Then give the tag a dash style in the Tags panel. DO NOT give the tag to the edge.
thank you
I cant find this tag lines options in the picture…its is in which version of skp?
Dashes were added to SketchUp 2019 and all versions since have that option in the Tags panel. If no dash style is selected it’ll show “Default” in that column.
where is the dash style? not finding it
As we’ve told you several times. In the TAGS panel.
is NOT
What version of SketchUp are you using? Your profile says you are using 2020. Tags should look like this without the first two buttons to the right of the Search field.
Maybe you just need to scroll over to the right in the panel or make the panel wider.
2021 now
Fix your profile. And the Dashes are there to the right of the colored squares if you make the Tags panel wider.
now i find it, it was hidden!! thx
