Hello i m trying to import the attached kmz into sketchup and it fails everytime. I tried to do it layer by layer creating new kmz and it fails aswell.
Any input would be very welcome.
Thank you very much (61.0 KB)
Hello Vincent,
There’s noting in the KMZ you shared for SketchUp to import.
That is, the KMZ does not contain a model, there’s only a doc.kml
However, there is a way to bring the coordinate points contained in the KMZ into SketchUp
Change the file extension of Proyecto Terrazas Santa Teresa.kmz to Proyecto Terrazas Santa Teresa.zip
Then extract the contents of the .zip file
Within the extracted folder you’ll find doc.kml
Change the file extension of doc.kml to doc.txt and you can open it with any text editor like MS Notepad.
Open the doc.txt with Notepad.
Select All > Copy and then Paste into a spreadsheet application, like Excel.
After some prodigious editing you can end up with a CSV file like this…
Santa Teresa Coordinates List.txt (171.2 KB)
Then, you can import the coordinates list into a geo-located SketchUp model with this plugin…
Coords-Tag from Datum by TIG — SketchUcation PluginStore
Here’s the result…
Santa Teresa Coordinates List Import.skp (1.5 MB)
