Hello,
I have create a Collada file in ArcGIS Pro from buildings with texture.
When i import this in SketchUp the program crashes or displays the message that the Item is empty.
What’s wrong with this file?
I did an export to Collada from SketchUp, and see that it uses version 1.4.1, which it seems is still in common use. I tried a number of online converters, and none of them coped with your version 1.5 file. Do you have an option to export to Collada 1.4.1?
Having said that, SketchUp shouldn’t really crash, even if it can’t cope with a Collada 1.5 file. I will log a bug report about that.
I’m not sure how Mihai.s opened it, but he may have used Skimp or some other extension.
Colin, I just used MeshLab to import and export as DAE, then in SketchUp I applied the textures.
That’s why I asked what the building looks like in ArcGIS, because it may be much easier to model and texture it in SketchUp directly.
Thank you. That’s the good texture.
ArcGIS Pro can only export as Collada 1.5 and SketchUp you say can only import as 1.4.
With FME i also can import and export the dae and then import it in SketchUp (without Texture).
Its strange that Sketchup Pr 2021 not the newest Collada structure can import.
And its not a good solution to use Blender because i don’t have that program and its a extra step.
I know that ESRI is starting to utilize the gltf format. By chance, does ArcGIS Pro provide you with an option to export gltf? I believe ESRIs CityEngine has the capabilities although it is not the same application as ArcGIS Pro.
