Muro Entramado S_406 mm Door test.skp (525.8 KB) Hello! i´m developing a wood frame
Wall panel which has the ability of being resizable at the time of keeping the spacing of the individual studs, and has double studs on every edge of the plywood sheets, so far so good.
Then I decided to add the ability of including a door and window structure, which was easy to do, but the problems come when I try to hide the individual studs that are in contact with the door or window structure. because, when I try to hide those, based on the position of the door elements, all the studs of the same name dissapear, any thoughts?
