Hi Sketchup Geniuses!
I have a file that has “Dark” Circles and therefore will not push pull. Is there a way to fix this? I am attaching the file.
Thank you!
Taylor 4 Ms. Wheeler.skp (162.2 KB)
Thank you!
The "“Dark” edges are Profile edges. They appear with many of the circles because the edges aren’t spltting the face into inner and outer faces. Trace an edge of the circle with the Line tool. When the circle shows as thing non-profile edges you’ll be able to push the face through.
This often happens if a circle with its interior face is copied. If you select only the edges of the circle and copy them, the heavy profile edges generally won’t be shown.
Just as an aside, you have less work to do if you first create the bottom face, then the first circle, detete the face inside it, copy the circle to create all the holes and lastly push/pull the face to thickness.
Once again, Dave, you rock! Thanks for your guidance!
Good tip! Thanks!
