If you haven’t got the backup file and the.skp file is as bad as Colin found it to be, the most logical thing would be to get started making the model again. Make sure you are saving it to your local drive and also publish it to your Trimble Connect storage asa backup.
Okey, thankyou for the suggest
Good luck.
I use this utility on Windows:
It is fantastic. Search for .skp or .skb, and immediately you have a list of SketchUp files and backups from everywhere on your computer. It can be a fast way to find models that you or the OS had put into unexpected places.
hello sir, im depressed my file cant open cause unexpected file format can u help?
this for the link
One of those files is entirely made up of zeros. The other one is 3/4 filled with zeros.
hello, im depressed my file cant open cause unexpected file format can someone help?
this for the link:
@colin can you help me
Yes I can!
Thank you so much, is there anyway i can fix file myseft when it happen again
We don’t yet know how the model gets into the state it does. All you can really do is keep frequent backups, and if you see the problem again, try to remember what you had changed recently in the model.
Hi, Colin. i have a file can not be open, was made on sketchup 2020 pro, now i´m using sketchup 2022, but even in sketchup 2020 iit was not able to open the file, not even the temporary file, can you help me please. Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
The SKP is scrambled in some way. The SKB works ok. I opened that and saved it as a 2020 file. Here’s that file:
If you see that opening the file and doing certain things, leads to the file being scrambled, let me know what changes you had made.
Hello Sir can u help me how to fix my broken sketchup file…
Post the file or a link to it so others can take a look at it.
Your profile indicates you are using the free version of SketchUp which is web based and would mean you should have some previous versions in your Trimble Connect storage. Have you looked there?
