Hey!
So far i have found creative ways to get to what i wanted but since with time the objects or shapes i create are getting more and more complex im really breaking my head on it.
So is there an easy way to find the frame work of a complex 3d shape? My shapes are built from triangles most of the time (geodesic dome style) and i would like to know how to get the measurements of the boards i need to cut in reality so i could build it.
Yeah it looks right, but once you look deeper in to the triangles you see they are impossible to build. Its like the boards will have to be twisted and different thickness on top and bottom. Donno if you understand what i say…
that will be correct but i will have to put spacers in the back between the big pieces and by that im loosing strengths on the structure.
maybe it is just impossible to do. flower3s.skp (230.9 KB)
What about this, Since the design is symmetrical I have taken one section and made it into separate straight frames. You can see how they interact and adjust them to fit. Depending on your boards. Then array a full set. Without the innermost triangle you could even reduce the number to be modified by half again. Or flipped components instead of the groups I have used. So for this specific shape you would need to adjust 15 to get the 464 needed. Individual frames.skp (119.2 KB)
I have tried to find the frame work on the separated pieces like you suggest here.
you can see on the file i sent on a the message above what happened.
i dont really understand how can i adjust them to fit like you said. in the sketch you send they are all connected on the bottom but there are spaces on the top and thats not what im looking.
Actually i think that it is geometrically not possible on that specific shape. and thats why we are having hard time to do it.
or maybe i need to try and get to this shape differently.
Yes, the shape you want is impossible with square frame sections, so by making the square frames you can see where you need to slice them to make the fit together.
If we are talking timber, they need to be wedge shaped and mitred. So by positioning each frame push pulled naturally you can see how to fit them together.
To make each, I double click each face and make it a group, then extrude it.
