Does Sketchup have an extension that allows us to drop many small components onto the surface of a volumetric 3D solid?
Typically, one would use Drop GC to drop a bunch of components onto an undulating sandbox surface.
But in this case, what if we had a 3D volumetric solid in the shape of an egg - instead of a sandbox surface. And all the tiny small components need to be dropped onto / surround the entire surface of the egg-shaped 3D solid?
Yes, but skatter does not wrap the components around a 3D volumetric surface.
I am looking for a Drop GC equivalent tool that wraps itself on a 3D volumetric surface, not just a single undulating surface from the sandbox tool set.
Just one final question. These components are populated along the surface of the globe.
Is there a tool within Skatter (or perhaps an external tool) that would populate components WITHIN the globe itself. Meaning, the components will hover in space, inside the 3D volumetric globe.
With âMake furâ plugin, if you change ânormalsâ (reverse faces), then you will get your component on the white faces, which will be inside, and the blue faces outside.
Just one final question. These clones are populated along the surface of the globe.
Is there a tool within Skatter (or perhaps an external tool) that would populate components WITHIN the globe itself (not by reversing the normals / faces), but with the components HOVERING IN SPACE, inside the 3D volumetric globe?
It seems by default that you canât Skatter inside the group - even when I râeverse facesâ it Skatters to the outside. You can however use Fredoâs Joint push pull which gives the sphere or volume a âthicknessâ and thus puts the components on the inside:
Hope that helps. By the way, as a Landscape Designer by trade, I love Skatter. So Iâll always advocate for it even if it doesnât do everything one would want/
Itâs like the Little Prince book. I live on a planet thatâs so small a short walk will take me all the way around it. of course now I need a rake for the volcanoes.
